Ist das kompliziert, wenn eine Zelle defekt wird?
@Frank Sounds complicated to me, I wouldn’t dare open the pack!
Nicht wirklich, wenn man weiß, was man tut – man tauscht einfach die defekte Zelle aus und balanciert das Pack neu.
I’ve done that before – but it’s not for beginners. You have to check the voltages carefully.
I’d rather let a professional handle it – wrong balancing can ruin the whole pack.
I’ve done that before – with some know-how and the right tools, it’s actually quite easy.
Yeah, I’ve done it once, but honestly, I’m not sure I’d do it again. It’s pretty tricky, especially with the BMS and all the connections. If you’re not confident, things can go wrong fast.
