Ich will sicher sein, dass keine Spannung einbricht.
If the LiFePO₄ supports enough continuous and peak current, it’ll handle the winch fine. Just check the max discharge rating.
@Philipp_Waves Just check the winch’s amp draw and compare it to the battery’s specs. Numbers don’t lie—then you know for sure.
