Can anyone explain how to correctly connect multiple 12V 280Ah LiFePO4 batteries in series to increase voltage for my system?
Connect the positive of one battery to the negative of the next, and repeat. Only use one positive and one negative terminal to your inverter. Make sure all batteries are same model and charge level.
Ganz einfach – einfach Plus mit Minus verbinden, aber überprüfe die Polarität, bevor du es einschaltest!
