Is it safe to charge the 12V 280Ah battery with a 20A charger, or should I stick with a higher amperage charger?
@oliver_hartman I’m using a 20A charger too! It takes a bit to charge, but it works great and doesn’t heat up or anything.
Kein Problem! Mit 20 A dauert’s halt länger, aber ist absolut sicher.
20A works… but it’s slow like a snail on vacation. If you’re in a hurry, give the battery more amps.
